ikrom
  • Ответы 6,1k
fanat15     Вот готовый викард установите с флешки .Турки сразу откроются
  http://www.uzsat.net/index.php?app=core&module=attach&section=attach&attach_id=19529
готовый то понятно ну хотелось разобраться самому что делаю не так я в этом деле новичок хочу научиться вот конфигурации....
[global]
active = 1
log = /tmp/wicardd.log
log_size = 200
debug = 1
[webif]
port = 8888
active = 1
debug = 0
[dvb]
filter = dvb
active = 1
auto_update = 1
ecm_info = 2
gebug = 3
[reader]
name = funcard
filter = bloker
type = funcard
force_ua = 662106B3
fw_file = /var/etc/dre/FunCard.a90
extee_file = /var/etc/dre/ee.bin
intee_file = /var/etc/dre/int_ee.bin
extee_size = 16
snippet_file = /var/etc/dre/initial_snippet.bin
emm_cache = 0
auto_update = 1
debug = 1
active = 1
[filter]
name = dvb
type = ecm
rule = caid=4ae1;ident=14;accept #(43card 56E)
rule = caid=0500;ident=042300;accept #RTVi
rule = caid=0500;ident=023800,030B00;accept = EMU
rule = caid=0500;ident=050C00;accept #(NTV+56E)
rule = caid=0500;ident=040600;accept # NTV+ (SD)
rule = caid=0500;ident=040620;accept # NTV+ (HD)
rule = caid=0B01;ident=0;accept# Kontinent
rule = caid=2600;ident=0;accept=EMU
rule = caid=0652;ident=0;chid=15,FFFF;accept #Raduga
rule = caid=0500;ident=007400;accept=mezzo
rule = caid=0B0F;ident=0,1;accep #Xtra
rule = caid=4ae1;ident=11;accept=bal #Center(13card 36E)
rule = caid=183D;ident=0;accept# Tivusat
rule = caid=090F;ident=0;accept# Viasat_Baltik
rule = caid=093E;ident=0;accept# Viasat_Nord
rule = caid=0D00;ident=0000C0,0000C4,0000C8,0000CC;accept#DigiTurk 7E
rule = reject
[filter]
name = dreemu
type = emm
rule = caid=4AE1;ident=14;accept
rule = reject
[reader]
active = 1
name = golda
type = goldcard
filter = dreemu
fw_file = /var/etc/dre/picsib.hex
extee_file = /var/etc/dre/ee56.bin
emm_cache = 0
auto_update = 1
debug = 1
active = 1
[reader]
active = 1
name = EMU
type = emu
file = /var/keys/SoftCam.Key
filter =dvb
[reader]
name = mezzo
type = emu
file = /var/keys/SoftCam_mezzo.Key
recalc_cw_checksum = 1
filter = dvb
[filter]
name = bloker
type = emm
rule = caid=4ae1;privdata=fe01,110010000102,110000000102,sid!=697D,6982,6987;accept
rule = fakecw
debug = 1
[reader]
active = 1
name = shara
type = newcamd525
account = ********:********@***************
multiport = 3000
degug = 1
filter = dvb
[reader]
name = goldcard
filter = bloker
type = goldcard
fw_file = /var/etc/dre/picz.hex
extee_file = /var/etc/dre/ee36.bin
emm_cache = 0
debug = 1
active = 1
[balancer]
name = bal
chain = funcard;goldcard
lease_time = 1
mode = 4
debug = 1
active = 1
[reader]
active = 1
name = NTV+
type = newcamd525
account =
debug = 1
filter = dvb
fanat15
Слишком много фильтров, должно быть не более 15.
Фильтр отвечающий за DigiTurk 7E
находится у вас на 16 месте, поэтому и не работает. Просмотрите предыдущие фильтры и удалите те, которые не используете.
fanat15
Если же все фильтры вам, так сказать необходимы и вы с ними не хотите прощаться, то можно некоторые из них объединить, тем самым уменьшиться общее их количество, при этом ничему мы не навредим.
К примеру вместо вот этих трёх фильтров:
впишите только этот объединённый:
rule = caid=0500;ident=050C00,040600,040620;accept #(NTV+)
fanat15 пробуй и проследи чтоб сам SoftCam.Key был прописан именно так и не как иначе...
[global]
active = 1
log_size = 200
debug = 1
[webif]
active = 1
port = 8888
debug =1
[dvb]
filter = bloker,boxcard
active = 1
auto_update = 1
ecm_info = 2
gebug = 1
[filter]
active = 1
name = bloker
type = emm
rule = caid=4AE1;privdata=FE01,110000000102,110010000102;accept
rule = reject
[filter]
name = boxcard
rule = caid=4ae1;ident=14;accept=golda
rule = caid=0500;ident=040600,040620,050C00,042300,;accept # NTV+ (SD)
rule = caid=4ae1;ident=11;accept=funcard
rule = caid=0D00;ident=0000C0,0000C4,0000C8,0000CC;accep=EMU
rule = caid=2600;;accept=EMU
rule = reject
[reader]
active = 1
name = funcard
filter = bloker
type = funcard
force_ua = 662106B3
extee_size = 16
emm_cache = 0
auto_update = 1
debug = 1
[reader]
active = 1
name = golda
type = goldcard
filter = boxcard
emm_cache = 0
auto_update = 1
debug = 1
[reader]
active = 1
name = EMU
type = emu
После включения тюнера из режима экономии энергии, не работают плагины OSDClock (не отображаются часы на экране) OSDShell (не срабатывают цветные кнопки). Эти плагины начинают работать только после нажатие на кнопки пульта (софт кнопки ввер-вниз, ок-exit). Вопрос: Как можно исправить это, или это у всех так?
где? тут одни конфиги.... :cray:
думал конфиги и есть лог.. как можна извлеч лог файл из тюнера?
Saylr Вы вероятно когда свои данные вводите в конфиг,допускаете где то ошибку.
В этом причина того что у вас шара не заводится.
Я на этом паравозе,с таким же конфигом,на таком же протоколе,всё отлично работает.
если ошибка было newcamd не работал бы. переключил newcamd из за безисходности
